DVDFab DVD Copy can flexibly copy DVD to ISO besides to disc or movie folder. It’s easy to use and professional for users to customize the output the way they like. Now let’s have a look at how to make the DVD to ISO copy via the following step-by-step tutorial.
Step 1: Start up DVDFab 9, choose Copy option, and load in the DVD source
Start up DVDFab 9, and choose Copy option. Then insert the DVD disc you want to copy into optical drive and seconds later the movie will be imported into DVDFab.
The Main Movie copy mode will copy the longest movie title.
Full Disc mode will copy all the content on the source disc.
Step 2: Select the output type and choose a directory for the output
Now let’s go to the lower part of the interface. Choose DVD5 or DVD9 for the “Output” according to your need.
Then click the image file icon behind the “Save to” box to choose a directory for the output ISO file.
Step 3: Start copy
Click Start button to start copy process.
During the process, you can view all detailed progress info.
OK. Now leave the rest to DVDFab 9. More info about how to copy a DVD, just go to: https://www.dvdfab.cn/dvd-copy.htm
